Hello I am having issues with getting a deep/solid color over reflective chrome when I go to use the second coat for the color that I desired especially the gold. I have had sucess with spraying the powder on a hot part and it instantly flashes but I assume there should be a way to re coat with good results on a cold part with a reflective chrome base. I have a clean grounding point for the ground as well. I am not sure if there is a preperation step that I am missing or what but any advice would be appriciated. And any info on using an epoxy primer powder then a chrome powder then followed by a colored clear if this is even doable
Thanks for your time guys
Ben
