cheap and easy heating elements DIY oven
  • #32220
    KK302
    Anyone using these ceramic cone heaters in the ovens? They are about $25 each and can just mount into a ceramic light socket. They also have a cheap little controller, I think it was $18?
    cone heater: http://www.akinsun.com/Accessories4.html
    contoller: http://www.akinsun.com/TempControls6.html
    What are your thoughts?
    I guess you could scavage an old oven for the controller too. Nice thing is you can go with 120 volt or 240 depending on which one you buy? I was thinking one of the 1000watt or two of the 660 watt 120volt cone heaters and I can just plug into any wall outlet? Do you think that would be enough for a small 24 inch by by 30 inch high oven? I know it may take a little longer to heat up but I’m not doing this everyday.
