I am in the process of preparing the frame on my restoration. It has been blasted and I wanted to coat it with primer immediately. I used eastwood self etching primer. I’m wanting to have the best possible coating on my frame and was reading that this primer cannot be used with certain topcoats. Should I start over and use a different primer in order to get the best end result. I am preparing the frame to be coated at a later time, just didn’t want it to flash rust in the meantime. Any advice you can give would be great. Thanks
