Good day Kevin. I am currently in the process of restoring/modifying a 1980 z28 fallowing closely to zedsled. Soon I will be done body and looking at suspensions. I want to use the stage 3 from CCP as you did. Was wondering if you upgraded the brakes or are you using the 11″ that come with the kit. Also could you tell me any other upgrades you did to the kit other then adding the steering box. With the c5 front spindles are the front wheels different bolt pattern then the rear. I find the CCP catalog a little confusing with so meany kits. Any help would be great. Also there stage 3 kit only list up to 1878. The stage for says it’s good for upto 81. Any ideas as to o why. I emailed them but haven’t heard back.
