Brake pressure bleeder
- This topic has 0 replies, 1 voice, and was last updated 12 years, 10 months ago by .
OK, two questions.
1. I see several “power bleeder” offerings, like Item #50137. For each different vehicle type, am I expected to buy a separate setup? I would expect that adapters would be available for different master cylinders, but the same main reservoir and pump would be used for all.
2. If I have vehicles that use regular DOT 4 fluid, and others that use silicone DOT 5, would you use the same bleeder device for both? What sort of cleaninig would you have to do to switch between one and the other?
Thanks.
-Steve Trovato
strovato@optonline.net
