body filler over fast etch?
  • #33177
    73L48
    can i use body filler over fast etch, or must i epoxy primer over fast etch. i just finished welding, grinding and fast-etching a rocker panel and cab corner and will need to follow with body filler. i know i’ll have to use PRE/acetone to prep the metal before either primer or filler, but i don’t know which is the correct step that will yield the best result
    thanks in advance – i appreciate it
    sean
