Basic questions related to PC and corosion resistance
- This topic has 0 replies, 1 voice, and was last updated 11 years, 8 months ago by .
I have a couple steel automotive suspension pieces that I plan on powder coating. I bought some hotcoat rally wheel silver powder and some eastwood fast etch for prep. After talking to a local aftermarket parts manufacturer about how well their powder coated parts hold up, they told me the they use a primer. Before powder coating my pieces, I figured this would be worth looking into. In searching for products that Eastwood sells, I came across Hotcoat Powder Corrosion Resistant Primer. I also came across GraySelf Etch Primer Aerosol. I’m wondering which of these products I should go with. My thinking is in line with the part manufacturer’s, that is, if a rock gets kicked up and puts a chip in the powder coat, the primer is underneath to continue to protect against the elements.
Furthermore, the pieces that I’m going to powder coat were covered in a thin layer of motor oil to protect against immediate corrosion after being sand blasted. I’ve read that the key to good adhesion is in the prep work. I have an industrial parts cleaner at my disposal, but have read that brake clean & simple green work well. Do I need to do anything else between cleaning them and applying the eastwood fast etch as well as between the rest of the painting processes?
Thanks in advance!
