Application of rust mgt products
  • #27029
    JohnA
    I have a project car that has surface rust on the frame, trunk and interior floor and a few body areas and need some direction as to what products to use for each area. It seems easiest to use RE for the frame and interior floor although there are areas where I cannot wire brush off the surface rust. Do you just use the aerosol product in these areas or do you use the rust remover and then paint? On the floors I can wire brush the surface rust off and then apply RE over it, but it would it be better to use the remover and then paint it? The trunk will need to be splatter painted once the rust is dealt with, so is it better to use the remover, or just use RE and then paint over it?
    So many choices!
