Amateur Polishing assistance
I got a wheel smoothing kit as well as a wheel buffing and polishing kit, but i have some issues.
The 80 grit paste is wonderful, it removed all the scratches I had from different areas. Then I moved to the 220 grit, in opposite direction from the 80 grit, and got rid of the 80 grit scratches. Same with the 320 grit, I have a satin finish, which is what I want.
However, when applying the Tripoli compound, there are minor scratches left, which are obvious on the jeweler’s rouge compound after buffing. No matter what I do, those minor scratches from the grit compounds don’t want to go away….what am I doing wrong? any tips?
