the instructions state that the rubber air line should not be more than 25′ for the concours gun.
yet, you give instructions on how to build a pvc pipe run. is the 25′ just for any “soft” line and does not
include the “hard” pvc line? I have the concours spray gun and would like to do the up and down pvc pipe
as you have in your videos. I want to do this so I can place the bottom of the pvc run into a container of
ice water in order to cool the air and attempt to avoid water out of the gun. will use desiccant throw away air
dryer at the gun, with a water trap after the pvc run. probably do not have the correct names for the air dryer
and water trap.
tks
