5.5 cfm compressor with 7cfm blast nozzles?
Posted: October 5, 2006 By: laurinap
Home Forums Ask Eastwood Ask Eastwood Archives 5.5 cfm compressor with 7cfm blast nozzles?
  • #30167
    laurinap
    since i am stuck with 110v in my rented space, the best i can do with an air compressor is an awful 5.5cfm… will i be able to use a blast cabinet with the 7cfm nozzles? will it get the job done, just perhaps slower?, or asked another way, will it work just the same in spurts, but with more “rest” time to let the tank fill up with pressure? does the compressor rating mean the level of constant flow the pump puts out, but in essence the effective output from the tank could be higher cfm’s in periodic bursts as the tank supply gets momentarily depleted? thks :confused:
