I need to do these 22″s in Solar Rain with the outer ring in Candy Red. They are chrome, so just a wipe down and shoot on both pieces. Then theres the assembly /disassembly. If you notice the big bolt heads((10) need to be pulled out carefully(they are plastic and being replaced), then there are 18 button head screws that need removing, plus 18 plastic inserts in the bolt holes for the outer rings that need to be removed. I dont mind giving a good deal , but these bolts and stuff are time consuming. The big bolts have to be carefully pried out with pliers to keep from scratching the chrome.
