1957 Ford just bead blasted
  • #35588
    57ford
    Participant
    Just got car back from bead blasting. The car has a lot of heavy pitting and pin holes in the roof dip rails and rear window area. Not sections that are weld able. Question what to do next for long lasting repair ?? clean all areas with “After Blast”?? Which spray sealer to use to cover pitted areas?? before using filler and primer?? Thanks for the help!!! John
