10 Tricks to remove that Stuck, Seized, or Stripped Bolt/Nut
Posted: August 29, 2011 By: MattM
One of the biggest frustrations when disassembling a vehicle for restoration, or even repair, is the dreaded seized or stripped bolt. Stuck hardware occurs when a bolt, nut or screw gets corrosion between the threads and they won’t budge. Many times, this leads to breaking the bolt off and having to drill and re-tap the hold or trying to remove it with a bolt extractor. I won’t even mention what happens when the drill, tap or extractor breaks off in the same hole!!
Below are my top 10 ways to deal with getting these suckers extracted without wrecking the precious part they are in. This include tips on how to remove a rounded bolt or a bolt with a stripped head in addition to those that are seemingly stuck in place for all eternity.
1. Blunt Impact/Force – This is usually my first step when attempting to loosen stubborn bolts. I always use this method before I begin removing exhaust studs from a cylinder head. There are a few methods for this. One is to hit on the head of the bolt in the center with a chisel or punch. Another is use an impact wrench/gun and hit it a few brief times in reverse and forward. Either of these methods work on the theory of freeing the corrosion bond between the threads by vibration or impact. It works sometimes on lightly seized bolts but isn’t a 100 percent winner every time. Keep in mind, though, that it can be combined with many of the other methods to help make the job easier.
2. Heat – If you paid attention in chemistry class, you would have learned that when you heat and cool metal, it expands and contracts. The way that I have used this in the past for removing a corroded bolt is to heat the head/body of the bolt until it is almost red hot. By doing this the bolt expands due to the heat, and when it cools it will contract, thus breaking the corrosion in between the threads. A similar method is to heat the area around the bolt to make the hole it is threaded into actually expand and open up a little bit. The bolt then fits a bit looser and can be threaded out. Use of an impact wrench or gun helps when initially breaking it loose since the force from the hammering of the impact wrench breaks the corrosion apart as well. Use penetrants like Kroil or CRC Freeze-Off to aid in the removal process.
3. Relief Cuts – This is my “sure-fire” method for removing most stripped bolts/nuts. It isn’t as clean/civilized as the others, but it is a heck of a lot faster! With this method you will be putting 2-3 cuts in the bolt head or nut. You want to cut just enough that you are almost all the way through the head of the bolt or the nut. You then can hit the cuts with a chisel and a hammer a few times, thus splitting the nut or bolt and relieving the tension on them. With nuts, you can normally just split it off of the bolt, clean up the threads, and install a new nut. With bolts, you can use some locking jaw pliers to grab the bolt head and turn the bolt out, usually the relief cuts will let the pliers squeeze the head of the bolt enough that you can turn it out easily.
4. Rock the Bolt – This is another one to try early on in the bolt removal process and in conjunction with other methods. You want to slowly work the bolt/nut back and forth. I like to take a ratchet and loosen the nut/bolt a little bit until it gets a bit of tension behind it again, then go back the other way and turn it to almost where you started, before loosening a little bit further than last time. As you expose some of the hidden threads, you want to spray some penetrant on those threads so that the penetrant works its way back into the hidden threads. It can be a slow process, but I’ve gotten some pretty stuck bolts out this way with a little bit of patience.
5. Drill’er Out! – This is the same concept as the relief cuts with a couple small twists or surprises that can occur along the way. I like to use this one as more of one of my last-ditch efforts or if the bolt has broken off flush with the surface. What you want to do is take a small drill bit and drill all the way through the bolt. This uses a bit of the chemistry a few of the other methods use. It heats the bolt by drilling it, and it also makes a hollow portion in the bolt so it can contract more as you attempt to remove it. I’ve had times where just drilling the bolt will allow the bolt to turn out quite easily. Other times, you may have to keep stepping up your size of the drill bit with a drill index until you are just a bit smaller than the diameter of the bolt. At this point, you may be able to carefully chisel or break the bolt apart in the hole. You can then extract the pieces and clean the threads back up with a tap set or a universal tap tool.
6. Weld’er Up! – This is one method for how to remove a stripped bolt that can be used if the nut or bolt head is so severely stripped you can’t turn it with locking jaw pliers. It is also useful if the head is broken off the bolt. You can simply take a washer and a bolt of a slightly larger size and tack weld it to the bolt body. Once you have it tack welded, I like to fill the nut with weld and run a bead around the base of where it meets the bolt body. This allows you to put a socket on the bolt again as well as putting heat into the bolt that will allow it to expand and contract, breaking some of the corrosion. I prefer to use a MIG Welder to do this job as it allows for a little more control than with a stick welder.
7. Air Hammer/ChiselThis combines a few of the methods already mentioned. Its biggest advantage is that it can be used when the bolt head is stripped. This makes it helpful when you’re trying to figure out how to remove stripped lug nuts and door bolts. You basically chisel/hammer it so that the bolt loosens. I have had it work with moderate success, but it needs to be on a bolt/nut that is an open area.
8. Bolt or Screw Extractor There are many styles/gimmicks. Some work, but many do not. They use hardened bits that grab into the inside of the bolt or nut to remove it. Many require you to drill a small hole in the bolt, then thread these bits in. Whatever you do, do not break the extractor off inside the hole, or you are in for a long, horrible process. Normal drill bits will not touch these, so you will need specialty drill bits to drill through them. If the stud is still present you can use a Threaded Stud Remover to extract a stud without damaging the threads or hardware.
9. Pipe Wrench – This is a pretty basic way to tackle a stripped bolt, and most everyone has a pipe wrench kicking around their shop. Tighten the pipe wrench down on the bolt/nut and as you crank on the bolt with the pipe wrench, it actually grabs harder onto the bolt head. Just watch you knuckles if it slips off!
10. Reinstall Bolts That Surround the Stuck Bolt/Nut – Sometimes, a number of bolts in an area will hold a part on. Occasionally, these are meant to be removed in a specific order. Make sure you check your repair manual for any installation/removal order. If there is none, I like to work from the center and work your way to the outside. Reinstalling some of the bolts around the stuck bolt may take some of the force off of the stuck bolt and allow you to remove it. This can take some time when you are removing a broken bolt, but is also less likely to damage surrounding areas than some other methods.
Related Eastwood Products:
88 thoughts on 10 Tricks to remove that Stuck, Seized, or Stripped Bolt/Nut
  • I am changing the water pump and radiator on my old truck. The last bolt on the right (behind air compressor and all) will not come out. Thinking it’s gotten hot and “welded the bolt to the block. Any suggestions? ?
  • Think about the thread pressure. For stuck nut or bolt hammer hard once or twice. The impact should drive into the threads. This breaks the rusted bond of the two metals and usually loosens it just enough. Also use candle wax and heat. Use the wax like you were sweating a pipe. The wax is drawn into the threads and acts as a lubricant. Have fun
  • I am replacing a toilet and one of the nuts are stripped. How can I get it off without having to break the toilet???
  • I’ve spent a lifetime fixing, restoring and repairing old cars, bikes and tractors and corroded in bolts and studs are a constant pain. Firstly make sure your tools are a good, tight fit on the fastener. Cheap sockets or wrenches make rounded corners almost certain. If you can heat the item normally by running the engine or taking it for a run do so and as soon as your back spray liberally with release oil of your choice and let it cool completely, overnight if possible. If I’m planning to work at the thing on say Saturday I will do this each evening from Wednesday. Be conscious of the diameter of the threaded parts a 6mm m/s bolt will not survive the attention of a 3/4″ socket and 3′ breaker bar.
    Sometimes an impact driver works wonders on smaller diameter fasteners, it doesn’t apply too much torque preventing breakage but hits it repeatedly which can break the corrosion’s grip. For the really stubborn stuff a mig welder is a godsend but you have to understand when you go down this rout the bolt, stud or whatever will be unusable. Also be careful of finishes around the work area, a welder, even a mig can do damage. Favorite method, used on Fordson tractor wheel nuts and similar. Heat to a dull red with Oxy/Acetylene and quench immediately with cold water. I actually had a wheel nut take the force of a 13 stone man standing on a 4′ breaker and not move, when this method was used the nut started and screwed off by hand. Remember many small steps to success is better than one giant leap to failure.
  • For rounded bolt heads that aren’t too badly stuck, you can use the cut off wheel on a Dremel tool to slice a slot in the bolt head and then use a screwdriver to turn it. A screwdriver probably won’t provide enough torque to pull anything really tough, but for a lot of jobs it’s a very fast and easy fix. Just don’t slice too deep and cut off half the bolt head.
  • The Fault in that were stripped and they were so badly stuck together they wouldn’t even move. Getting the toilet bowl off. Read a few. Now I’m going to try. Thank you
  • I just drilled out a motor mount boat and I had to retype it or use the 5/16 drillbit and tap to three eights by 16 for Rich to best thing is to use a small drove it at first dead center and then go little bigger to you get to your 5/16 and whatever you do do not break off Daisy out order tap I mean into the block they do have tours to take out the taps only three flare in for flair and maybe they might have to flare I don’t know anything about swirl
  • Having a nightmare of a time with 2 studs have snapped of on a crankcase. I have managed to get some studs out.
    I have welded this just sheared off, bought a odd looking stud remover and that just went round and around not gripping, stillsons worked the best but studs are now too short so might drill next
  • Thanks for the great tips. I’m in the process of replacing the cone-shaped front wheel bearings on a 2004, 2WD Ford Ranger and, wouldn’t you know it, the last caliper mounting bracket bolt head was so rusted that it rounded before I could get any loosening torque on it. I hammered the top of the bracket to loosen it a bit, put a vice grip on the rounded head and wacked the bracket with a rubber mallet. After a couple of good hits I felt the thread give, which allowed the bolt to unscrew. I’m getting a new set of 4 bolts for 14 bucks. Beats having to cut out the bolt of worse get a new steering knuckle.
    Your tips and those from the forum folks helped me a ton in time and treasure. Thanks a bunch!!
  • WD-40® SPECIALIST® RUST RELEASE PENETRANT SPRAY ACTUALLY WORKS QUITE WELL. But of course there is always one that just will not come out.
  • Yep a huge problem todays cars are worse in Australia anyway we have lost all our manafactoring to assia sad days ahead so car steel is coming from china low quality and ferris oxide happens in only afew years i always use a anti seiz copper grease as it only can help stop rust we uesd to add a few drops of oul but found penzoil soild this copper grease what do you guy think do you do a silular prosses or is my ocd over board we refuse to work for insurance mostly resto and private ..
Leave a Reply
